I think the standard coil is 1.5 ohms and the ballast resistor is 0.8 ohms for points
From my FSM, coils for my cuda could've been an Essex or a Prestolite p/n 2444241 and 2444242I have been searching for the proper coil for a dual point Prestolite dist, haven't really found an answer. Seems like points want a 3 ohm coil. So I was wrong thinking .6 ohm.
Having said all this, we do have a guy here, Halifax? Bet he knows. Why not pm him?
"The Essex coil features the part number 2444241 and the words Made in USA stamped on the side of it. The Essex coil was used in a good majority of vehicles produced from 1966 to 1971. The other coil that was used was known as the “Short Fat Type” and was manufactured by Prestolite. The Prestolite coil has part number 2444242"
Correct, I have the same info from the FSMAnd the dual point distributor used the same coils and ballast resistor
The Essex had a primary resistance of 1.41 - 1.55 OHMs
The Prestolite 1.65 - 1.79 OHMs
Both used the same ballast resistor - 2095501
0.5 - 0.6 OHMs
Current Draw - Coil and Ballast in circuit - Engine Stopped 3.0 Amps
Engine Idling 1.9 Amps
Right on the money there! Alot of guys run the 1 ohm resistor because thats what the parts store has. That is mesured hot 70-80F just FYIAnd the dual point distributor used the same coils and ballast resistor
0.5 - 0.6 OHMs
