65TerrorCuda
Straight out of the box. Dizzy 1 no mech advance, dizzy 2 no vacuum advance
Wow, what brand is that and where are you getting them from? Remind me not to buy one of those.Straight out of the box. Dizzy 1 no mech advance, dizzy 2 no vacuum advance
SKP or SKD, from Rock Auto. Honestly it's a bottom of the barrel dizzy which I shouldn't be surprised have this many problems. It's well made just poorly assembled. And now Rock won't replace it either, that hurts my feelings lolWow, what brand is that and where are you getting them from? Remind me not to buy one of those.
Oreilly sells new Spectra distributors. Same Canadian company that makes radiators, gas tanks and fuel senders. They are a decent product.SKP or SKD, from Rock Auto. Honestly it's a bottom of the barrel dizzy which I shouldn't be surprised have this many problems. It's well made just poorly assembled. And now Rock won't replace it either, that hurts my feelings lol
Thanks Rusty,Oreilly sells new Spectra distributors. Same Canadian company that makes radiators, gas tanks and fuel senders. They are a decent product.
You can slap a point distributor right in where an electronic came out on all the Mopar electronic ignitions. That's why the point style makes a great backup.Thanks Rusty,
I might get a new vacuum advance can for the original single points dizzy after seeing all this carnage. The ignition I'm using does either points or electronic. I am going to look at the Spectra as well
No joke? That's awesome! I learned something today.You can slap a point distributor right in where an electronic came out on all the Mopar electronic ignitions. That's why the point style makes a great backup.
Just get one from our member @halifaxhops
He will build it with good quality parts and can even tailor the curve for you...
You don't have to bypass the box?You can slap a point distributor right in where an electronic came out on all the Mopar electronic ignitions. That's why the point style makes a great backup.
Nope.You don't have to bypass the box?
WowMan, that's Cool! If I remember right. My points distributor just has one lead, off the coil, I think. Just hook it up and roll, huh?Nope.
Correct.WowMan, that's Cool! If I remember right. My points distributor just has one lead, off the coil, I think. Just hook it up and roll, huh?
As the cobwebs clear, it maybe the negative side of coil. That's actually Killer to Know Man! Ahh, the tricks and stunts unknown to common folks.... Thanks Rob! I have an ol points unit hanging out in the shop I built. Eliminates ALOT of Roadside Run tests, IF you have an issue! Personally, points have Never done me wrong. I put a Dyna Dual Fire elec ign on the 77 drag bike, at one point after a 1/2 rebuild, I went back to points. Fired right up!. Now, What happened to the Elec unit? Ain't seen it in over 12 years .... hmmm darn brain thing...Correct.
Here's one of Halifaxhop's distributors in my buddy's 69 Dart in case you want a reference... He curved it for us and we dialed in the timing...
Excuse the third one as I came off too hard and had to let off it early...
That's as far as you can move it, the pickup is jammed against the vacuum advance linkage. I was going to fix and keep it but I didn't feel like filing parts down. Afraid of what I'd find nextThanks Karl. In the picture it still looks like you have adjustment between the pick up coil and the reluctor. Should be .008-,010. Parts store distributors are a crap shoot with the curve they are made to cover a large span of curves over usually a 8-10 year spread. Some are great and some suck for your car but they will all make it run. Curve is the key to them.
I thought the wire colors were funny too. Spun real niceI see it now. Return it is wrong somehow cant tell by the pics what. . I have never run into that. By the wire colors definately a replacement aftermarket pick up. All mopar 8 except the MP are red and black,
All the pics are of dist 3. The reluctor roll pin was not seated and came out with the rotor, which was broken. I don't know what they did to make the pickup collide with the vacuum advance pin. And no, it couldn't get closer than about 20 thou.So can't tell from the small pics (phone)
Just for my own interest and info Dist. #1 the roll pin came out the reluct and licked it up braking the rotor/ cap damage?
#2 No adjustments to get the Magnetic Pickup to .008-.010? From cheap pick-up source when thet built it?
