So if ya have been following the recent issues I've been having with the break-in of the new motor, ya know it hasn't been going well. Overheating has been a big problem. Yes, we nearly killed the engine. We had a timing issue (which has been corrected since we did get the thing to run long enough without overheating to set timing) and we also had an issue with running too lean.
This weekend we drained the oil and put fresh Rotella in with new filter of course. Drained and refilled the coolant system and changed plugs (the original ones we used during break-in were burned badly.) Got the car fired up and everything went well (kinda). T-stat opened when it was supposed to and timing got set. Figured we'd remove the old exhaust manifolds and put the new headers/mini starter on to do the remaining 5 min. of the break-in, just cause I thought the manifolds were getting too hot and contributing to the overheating issue prior. Well, when we raised the car we noticed a coolant leak from the head gasket...BAD NEWS. Did some research and decided that where it was leaking (pass rear corner) that it was probably an installation error and not "blown" due to overheating. It isn't spewing, it's just dripping. This could have been the problem all along (or at least part of the problem.) Hubby said he didn't have much cooling system pressure when we checked the fluid during the timing setting.
So yesterday he called the engine shop that built the engine and told them about the leak. They agreed it was probably not torqued correctly and then said he could come by and pick up some adhesive stuff and put it in that corner and retorque to specs and everything should be fine since there was no crumbling/crushing of the gasket.
Question is...does this sound right to anyone else? I'm thinking that a head gasket is a major deal since you have to make sure the surface is smooth to no more than 0.004, the stretch bolts are new and torqued not only to the correct ft lbs but also in the correct sequence, yada-yada. Seems like too easy of an answer to me and we'll continue to have problems down the road.
I spent a ton of money at this engine shop for the rebuild (like over 6k) so I don't want a Mickey Mouse response to a problem when it requires a sounder solution.
Opinions? Suggestions?
