New For 2016 From PST A body Classic Update wiring harness
PST
Marketing Manager
FABO Vendor
Montville, NJ
Performance Suspension Technology (www.p-s-t.com) now has available the CLASSIC UPDATE wiring harness from American Auto Wire for your classic Mopar A body muscles car from 1967-75.
The Classic Update Kit gives you one of the most complete kits on the market to “Make Wiring THAT Easy”. They are designed for specific year, make, and model configurations. The 1967-1975 Mopar A-Body Classic Update Kit is no exception. The kit boasts 13 features making it the most complete system of its type in the industry including:
• A replacement headlight switch with internal 25-amp circuit breaker, adjustable length shaft, and custom knob.
• Standard turn signal flasher, hazard flasher, and horn relay mounted on harness.
• Fuse box designed to fit in original location with mods to the firewall, template included. All required hardware supplied. New ATO fuse panel allows for easy fuse and circuit breaker accessibility. Harness is laid out and formed to allow for nearly all after market accessories such as; gauge packages, wiper systems, heat and air conditioning systems, etc.
• Many original switch connector bodies
• Steering column connectors can plug directly into most aftermarket steering columns or stock ‘67-‘75 Mopar columns using the adapter and terminals included in the kit.
• Separate under dash courtesy lamp assemblies are also included for use along with your original dome/interior lighting feeds.
• Instrument Cluster wiring is designed with a “cluster harness disconnect” system for easy service and assembly. Original style terminals, lamp sockets, connectors, and locking nuts that will attach to the original cluster are provided for stock cluster connections. The system will also connect into most popular aftermarket gauges such as CLASSIC INSTRUMENTS, DAKOTA DIGITAL, AUTOMETER, VDO, and others.
• Rear body harness assembly plugs into the main harness in the stock location and our longer leads allow for stock or custom routing of the wires. Rear body wiring includes backup light lead wires with correct lamp sockets or connectors, stop and tail light lead wires with correct lamp sockets, dome light leads, terminals, connectors and lamp sockets to mate with the license plate lamp and side marker assemblies, and fuel tank sender wire with trunk grommet and tank connection.
• New floor dimmer switch is provided for ease of installation. Wire length and connection accommodate original floor mount dimmer switch.
• GM bulkhead connectors for the engine and front light wiring are included (another American Autowire exclusive) and allow for easy installation with original or custom routing.
• Engine wiring includes connectors for original points type distributors, OEM Chrysler style starter relay connections, tach and ignition leads, etc. High-powered 1-wire alternator connections are supplied.
• Front lighting includes extra long leads that can be routed for stock or optional applications. All head light, parking light, and directional light leads, along with a switched trigger wire for an electric fan relay (usually recommended with AC) are provided. Mating terminals and connectors are also provided for you to complete your custom installation.
• Many original style light sockets, switch body connectors, terminals, etc.
• This product covers the following year/make/model combinations:
o 1967-75 Dodge Dart
o 1971-72 Dodge Demon o 1967-69 Plymouth Barracuda
o 1967-75 Plymouth Valiant
o 1970-75 Plymouth Duster
Performance Suspension Technology www.p-s-t.com or 1-800-247-2288
I will verify the mounting of the fuse box with manufacturer. As for the price it is $759.
Thanks
James
I checked with the tech and AAW and the fuse panel mounts in the existing spot as does the bulk head connector.
Thanks
James
How long does it take to install in a typical installation?
Installation time would vary depending on the state of the car. Meaning if your car is in the midst of a restoration and you are in the process of reassembly things would already be out of the way which would make the wiring less time consuming. If you were to start with a complete car you would need to remove interior and other items to run the new wiring and grounds to the rear. So time would vary on a vehicle to vehicle basis. For a car that is assembled it would be a good day to day and half job.
Thanks
James
American auto wire makes a quality product. And this isn't a bad price for what you are getting. It's not some universal kit. It's abody specific. Try wiring your car the right way like this kit allows and see what it costs.
Does this have any advantages over a stock style repro harness that is plug and play?
I notice that this uses the later style fuses....
Are the connectors compatible with the stock connectors in our cars, or how do you hook them up to the headlight switch, wiper switch, dashboard, heater blower switch, flasher, cigarette lighter, etc???
I was at the Grand National Roadster show on Sunday and talked to AAW about this kit.
The guy I talked to said it's pretty complete. It's made to encompass all the different a-body types and options so it may have more circuits that you actually need for your vehicle, such as you might end up with extra light bulb holders and things like that.
I should have asked how thicker the wires are in comparison to stock, but I was pressed for time since I had to work a booth.
We normally have them in stock but we just sold 2 over the weekend so I would have to check. If we do not have it in our warehouse. We then would have it drop shipped directly to you. So we quote 7-10 days on delivery.
Thanks
James
