nm9stheham
If you can shift the ring around with your hand, then it is definitely too loose. Try crimping the lock tabs on the tank a bit with the new ring.Also, at this time, after shifting the locking ring around it does appear to be staying dry, but still I couldn't trust it, what if a pothole was to shift it six months later.
And the ring has some dimples that should slip into some matching indents in the tank's retention tabs; that keeps it from backing off or ever moving. If the indents are not in the tank's tabs, THAT is a reason to return the tank. If you are not getting the dimples locked into the tabs' indents, then the installation is not correct.
A lot of successful ring and gasket installation has to do with tools and technique. There is a special spanner for this that grabs the square turning tabs on the ring. If you don't want that, then I do it by tapping on the ring's turning tabs a tiny bit at a time with a small hammer and flat bladed screwdriver, and moving around on these 4 tabs to keep the ring as well centered as I can through the process. Using a sparing amount of Vaseline on the ring seems to help a lot in the installation.
