Mopar to ya
Tom and I finally installed the line locks on my Dart. I had so much fun I wish I had done this a long time ago. It just sits and smokes those tires now. We thought we would be smart and run power to the solenoid and use the switch to apply ground. That way the long wire through the firewall would not be hot in case of a short. Everything worked great until we hooked up the activation light. What Tom was worried about came true and the power back fed through and turned the light on when the key was off. Once the car was started it stayed off until the switch was depressed, but we wired it the right way after that. I can tell you I will be looking for new tires soon. This is a freakin' blast! If my daughter comes over tomorrow I will get a serious burnout video.
Hurst Roll Control solenoid
Solenoid with new brake lines made and run.
