Also ....
2.395One dimension I don't think I have written down on the spec sheet, is the OD of the tube.
I'm working on a 67 Barracuda FastbackThe part is going to be delivered to my tester soon. I know the dimensions are good on the bearing side, but I need to confirm the fit to the steering column tube. Stay tuned!
You may want to confirm that this is the part you are looking for. As far as I know, this is a 67 only part. Although, if your steering column shaft end looks the same as the renderings and pictures in this thread (2.25"id, 1" shaft, and the 0.5" keyway), this is the part you need.
