2fine69s
69 340-6pak Rag Top
Hey guys,
I have a really bad problem again!. I have bought 2 NEW (not remanufactured) master cylinders from Car Quest and both are leaking from the rear reservoir. So I need your help to let me know if Im doing something wrong. Her goes... I bench blead both. After, I let them set while I was getting my stuff ready to put it on the car. When I go back to get it, half the fluid has leaked from the rear reservoir brake line fitting hole. My thing is, if its leaking now I don't think its going to stop itself later, and when I apply the brakes the pressure will bypass the plunger seal cup. Am I correct, I need your input...
Thanks
Martin
Thanks
Martin
