[SOLD] NEW Mopar 3.55 ring and pinion for a 741 case
340man
Well Known Member
Legendary Member
Gig Harbor,Wa.
These new 8 3\4 3.55 and pinion gears are for a 741 case with 10 spline. New 3.55 ring & pinion set (part# 2070898/2070899,) for the 8.75" 741 case . All bolt holes good, threads on pinion excellent, There are Mopar numbers on the ring gear and pinion as stated above. I am asking 145.00 plus shipping. Thanks for looking..
Here is a used set I bought from a member a while ago, same numbers and gears and pinion for a 741 case.. it has no taper as shown in pics below. Take a look at pics below...
These new 8 3\4 3.55 and pinion gears are for a 741 case with 10 spline. There are Mopar numbers on the ring gear and pinion. I am asking 145.00 plus shipping. Thanks for looking..
Not to be a downer......that pinion looks to be tapered which would make it for a 489 housing, not a 741....not the end of the world if it is, still a desirable gear set.
Mopar ring and pinion#'s, it measures 1 3/8 pinion size and is 10 spline for 741 case... pm replied to...
After much checking and info from members the gears look to be for a 741 case. The middle pinion in pic below. Thanks to Daves69 for showing the differences in the pics below... Thanks for all your help...
I believe it's generally something like this...….
L to R... tapered ………. 489 case
small stem …...741 case
large stem ………742 case
