New Thermoquad Install-Engine misses
LJS30
Hemet, California
I just got done installing a rebuilt Thermoquad I purchased on the net and have an issue. At first the motor sounded great, idled fast, but ran great. I adjusted the idle, motor sounded great, then suddenly I have a miss. What could it be guys? I'm thinking a fouled plug perhaps? It's been a LONG time since I cranked this motor up so could a plug have fouled in the process?
Your plugs should be replaced. If the T-Q is to actually blame, it is most likely running lean. Back out the twin idle screws.
If you need any tuneing tips on that TQ, contact Demonsizzler.
Who rebuilt it? Sounds liek the well seals may be leaking... That causes them to run rich at idle. If you look down the carb just after shutting off the engien and see wet fuel on the blades it's more than likely well seals.
Thats what it sounds like, its running rich, this guy can build or fix any TQ out there.
www.thermoquads.com
