Ok first off this is not a mopar engine but im sort of practicing with an old lada 4 banger before i ever even think of rebuilding a mopar v8. So i thought i would just ask you guys since i dont really know any other forum.
I just finished puting together a small 4 cylinder engine. Honed cylinders and changed piston rings (and other stuff but that is not important to this question i think) when i turn the engine over by hand (sparkplugs intalled and cam timing should be correct) i can hear hissing sound from under the pistons as they compress air in the combustion chamber. Engine has not been broken and i did put oil into cylinders.
Might be a stupit question (sorry) but in this normal? Or did i do something wrong...
Thank you in advance.
