t2ae
Active Member
Hey guys, Ive been lurking and trying to read up as much as i can for information. I recently acquired my grandfathers 1973 duster upon his passing. As you could expect i am trying to iron out all of the loose ends that he was not able to finish. The car has a 340 that has been bored .30 over, has a holley 600 carb, eledrock ld340 intake, headman headers, unknown cam but seems somewhat aggressive. 3 speed auto transmission with factory rear gears and stall. I have started with verifying the compression which is around 165psi on all 8. i Then moved onto the timing which is where i am getting a little lost and could use some help. car runs and drives ok it just seems to be beyond slow in my opinion. I adjusted the timing to see where it like it the best and at idle it seems to be happiest around 20 btdc. it doesn't seem to really like that set on acceleration though. When revved up watching the timing with the curve it ends up around 40 total timing. Any idea the specs i should be after?
