fitchett
Active Member
what trannys work with small block mopars and how do u identify them do they have numbers on them.i have a couple laying around dont know what they r though.
there are slant six 727's out there.
If the transmission is a 727, it may in fact be a big block transmission, I'm not familiar with the difference between the big and smallblock trannies, But I believe the starter location is different somehow too.
i would like to see a slant 6 727.i believe they were never compatable with a slant 6. the 904 is 31 inches long and the 727 is 35 inches long regardless if it is a big or small block. the starter is in the same spot on both.
i stand corrected. so the /6 727 were never used in a car application...
