No brake lights or rear turn signals
Electrical and Ignition
  1. GreenVal
    GreenVal New Member
    1
    0
    Jul 12, 2018
    Los Angeles
    Local Time:
    5:02 AM
    Hi,
    64 valiant wagon v8
    Front blinkers, reverse lights, and tail lights all work fine.
    Rear blinkers and brake lights were working, but all of a sudden stopped.
    The fuses are all good and both filaments in bulbs look fine.
    Any suggestions/help is greatly appreciated.
    Thanks
  2. SGBARRACUDA
    SGBARRACUDA ROY FABO Gold Member
    13,279
    2979
    Dec 7, 2006
    PLANT CITY FL.
    Local Time:
    8:02 AM
    If it all checks out, then your turn signal switch is more than like bad.
    • Agree Agree x 1
    • retroron
      retroron FABO Gold Member FABO Gold Member
      590
      348
      Apr 9, 2014
      Livermore Calif
      Local Time:
      5:02 AM
      I'm not an expert on MOPAR wiring, but if the front front blinkers and tail lights are good I'd be looking for a broken wire.
      • Agree Agree x 1
      • SGBARRACUDA
        13,279
        2979
        Dec 7, 2006
        PLANT CITY FL.
        Local Time:
        8:02 AM
        I didn't catch that part. Your right if the front is good, it has to be in the rear harness. It runs down the left side inside. Should be a plug there at the left front kick panel, unplug it there and test the harness at the plug with a test light.
      • retroron
        590
        348
        Apr 9, 2014
        Livermore Calif
        Local Time:
        5:02 AM
        :lol: Even us old dogs get it right once and a while:rofl:
        • Like Like x 1
        • 67Dart273
          67Dart273 Well-Known Member
          38,632
          6243
          Oct 14, 2010
          Idaho
          Local Time:
          5:02 AM
          Access the switch and test for power at the wires leading to the rear. IF you have not done so, go to MyMopar and download a shop manual and or wiring diagram. It is likely the TS switch itself
