So I picked up this 65 Dart earlier in the week. The brake pedal seemed to go in quite a ways. I don't remember the last time I drove a car with manual brakes but I'm guessing modern power brakes stop a lot faster.
So I took off the cover to the brake master cylinder (is that what it's called?) and there's no brake fluid visible inside the reservoir. Not sure if any air has gotten into the lines? Obviously I'll need to add some fluid and bleed the brakes and check for any leaks, etc.
Can I use DOT #3 brake fluid to fill the reservoir up? Or do I need to use something else? I have some #3 lying around my garage which is why I'm asking.
Glenn
Glenn
