g413
I drive my 67 barracuda with a 318 2 bbl just close to home because it is not very reliable yet. A couple of weeks ago I thought I ran out gas, but a nearby friend pourred some gas in the carb and I got it home. I can't tell the gas level because gauge or sender is not working.
So I put several gallons in the tank. It still won't start so I disconnected the fuel line to the carb and cranked it about 20 seconds, and not one drop. I took off the fuel filter and tried it again -- not one drop.
So it seems like it must be the fuel pump or the pickup screen is completely clogged. And since there is no flow at all, I would suspect the fuel pump.
Anybody else had a fuel pump break? Is cranking for 30 seconds enough to get gas to the engine? Any other ideas?
