1. Xtreamist
    Xtreamist Well-Known Member
    46
    16
    Jun 23, 2018
    Central Ohio
    Local Time:
    3:01 PM
    I pulled the drums off the 67 Cuda over the weekend. Trying to figure out why the brakes don't work and go to the floor. The drums, shoes, and everything else in there look really good. There are no leaks in any of the lines, ect. Master cylinder is full of fluid. What are some of the other thing I can check? Maybe the master cylinder push rod is stuck?
    May eventually as least do a disk conversion on the front with a new MC but for now I would like to get the drums to work. I do have a Ford 9", not sure if that matters much. The PO did drive the car, though it was about two years ago.
    Any ideas?
  2. Lee Robinson
    Lee Robinson FABO Gold Member FABO Gold Member
    5,740
    180
    Aug 23, 2009
    El Dorado Hills, Ca.
    Local Time:
    2:01 PM
    Bad MC would be my guess, with no leaks as you describe.
    • Agree Agree x 7
    • 67Dart273
      67Dart273 Well-Known Member
      38,670
      6302
      Oct 14, 2010
      Idaho
      Local Time:
      12:01 PM
      MC has to be "primed." If you look up Google / etc "bench bleeding" a master cylinder you'll get lots of info. You need a way to keep the master from sucking air back in on the upstroke. There are all kinds of cheap tools for this, a kit of plugs, or a kit of adatper fittings with hoses, etc.
      bench bleeding master cylinder - Google Search
      Other than that.........
      1...Bleed the system
      2....Shoes may not be tight enough. For bleeding, until you are done with that procedure, tighten the adjusters up TIGHT so the wheels won't move. This locks the shoes in place and you can get a better feel for what is going on.
      • Like Like x 1
