Alignment is a topic beaten to death and I’ve read as many threads as I can find here, as well as B Bodies Only and E Bodies Only. I’m struggling to figure out what is going on with my alignment.
‘67 Barracuda, new spindles when I converted to 11.75 discs up front. Upper control arms from a ‘74 Dart with discs. Lower control arms are stock. I also installed new upper and lower ball joints as well as all new control arm bushings. Strut arm bushings are also new. All of the bushings were stock rubber replacements and the upper control arm cam bolts are stock. I also installed new torsion bars, hub bearings, and rotors.
A local shop did the alignment, didn’t take but a few hundred miles for the front tires to show outside wear, driver side much worse. Also, the steering wheel had no “desire” to return to center on its own.
I live in a small community, only two places do alignments here. I prefer to try an alignment on my own before going to the second shop.
For my initial settings: Rear control arm bolts are all the way in, front bolts all the way out. This resulted in camber to be positive 1.4° on both sides of the car.
Regardless of which side of the car I work on, adjusting the rear bolt causes camber to only gain more positive. I cannot move the camber less than 1.4° positive, while trying to gain negative, with any re-positioning of the rear bolt.
The only way I can gain negative camber is to move the front bolt well towards the inside of the car, which allows the .5° negative camber I want. This results in the rear of the control arm all in and the front of the control arm nearly all in.
Both sides of the vehicle have identical results.
I have no idea of my caster as I have not bothered to go past setting the camber.
I feel as though I’m backwards here. Does anyone have any insight?
Thank you
Thank you
