I'm lost. I have no power at the coil, the bottom left tab on the ballast resistor, and none on the field farthest from the main positive on the regulator. It cranks, and everything else seems to work ok, lights, etc. ICM is new, ballast resistor is new, ignition switch is new, neutral safety switch is new. Where do I look?
