Today I changed a freeze plug and replaced my coolant. I now have no leaks and the car does not overheat. The problem is the system isn't building any pressure. The system built pressure just fine before I changed the plug (even though the plug was slowly leaking coolant). I filled the rad with coolant just below the cap. The cap and thermostat were replaced a few months ago, so I know they are fine. Could it be air in the system? Would that cause it not to build pressure? Any advice would be greatly appreciated. Thanks guys.
