So there are ports between the timing chain cover and the block. I was unaware of this. Just thought there were oil ports there. Thats gotta be whats leaking. I'm wondering if I should just pull this motor and replace all the gaskets/freeze plugs.
No ports, a couple of the bolts hit water. Doesn't make sense to me, but I had a seep and that's what I did to cure it.
No need to pull the motor, just drain off some of the coolant and put some non hardening sealer on the water pump bolts and run them back in a see what happens.
