Dusterdenovo
Contentedly Old School
How were the shafts engineered/designed??? Did you reverse engineer them or get a hold of blueprints for the k-frame and design to those???
If reverse engineered, how do you know if the part that you used to design to was built to nominal and not at one end of tolerance or the other????
What quality control checks do you have in the process??? How often are the parts checked??? How do you check them, attribute or variable gauges???
Do you do SPC??? How capable is your process??? What are your Cp and Cpk numbers??? How do you quarantine out of spec parts???
See Boys and Girls - that's what a Technical Editor is supposed to sound like......intelligent
