MoparManimal
New Member
I'm having trouble tracking down an ignition problem on a 67 Coronet with an Orange box. Car ran great a couple weeks ago (minus the weak bottom end). I swapped the engine out and now I have no spark and I'm baffled. Everything is wired the same as it was. Dual pin ballast resister. Using my timing light I get flash on the wire going into the distributor but I get nothing coming back out towards the plugs. I feel like I've double and triple checked that the wiring is correct to the ECU and coil (using diagrams from other threads found on this site, actually). Black from the ECU on the - side of the coil. Dark blue and the brown ign2 "start" on one side of the ballast going to the + at the coil. Blue striped from the ECU mated to the 12v ign1 "run" on the other side of the ballast. All as it was before. I've got 5-6v on the coil + with key on and 9-10v when cranking (seems lowish?). Along with checking the wiring basics I've swapped everything (for giggles), 3 different ballast resisters, 2 ECUs, 2 coils, 2 distributors, caps, rotors... and back again. It's driving me nuts. I also added another ground strap to the block at the ECU and tried bypassing the ballast resistor completely. Still no spark.
It seems to me if I have spark going into the top of the distributor and I get nothing on any plug wires then it's either 1) weak spark but enough to trip the timing light close to the source (coil) but not very far from it (even right at the cap), or 2) the spark is happening at the wrong time and not making the jump from the rotor to the leads in the cap (which doesn't seem possible given distributor adjustment). Right? Am I missing something?
I think I'm in the forest/trees mode and I have to be overlooking something simple. A fresh perspective would be helpful. Any thoughts?
THanks,
Chris
THanks,
Chris
