jprkns
New Member
I recently removed my heads off the 68 barracuda 340 auto floor shift for a valve job. I had also pulled out the steering column to repaint. Anyway I’ve completed the engine portion and was trying to start it up last night and have no spark to the plugs. Coil tested ok but I replaced it anyway. Do you think having the steering column harness disconnected would prevent it from getting spark? Only things on the column are blinkers and horn.
