512Stroker
We are all here because we are not all there.
I recently did a 340 build that turned out sweet except for the valve clatter on start up.
I used a full Comp Cam roller setup, cam, lifters, rockers and springs. Custom length push rods were correctly measured and installed. Engine was professionally dyno'ed for breakin and pulled 442 corrected HP. Valvoline VR-1 10W-30 oil. I have tried preload adjustments of 1/4 and 1/2 turns with no change, it just clatters bad on hot or cold start up. After the engine builds oil pressure all is fine. 25 psi@ idle - 60 psi highway. The Idiots at Comp have no idea, they blame it on "poor Mopar oiling".
Help my hair is disappearing fast.
