Noisy elec pump
Fuel and Air Systems
  1. Garys72Duster
    Garys72Duster Well-Known Member
    469
    267
    Apr 23, 2017
    Brighton, Co
    Local Time:
    4:13 AM
    Just got a 70 Dart / 440 with a Paxton blower and electric fuel pump. Previous owner said it had to have an electric pump due to 7 or 8 pounds of boost. I guess that's true. But I don't like the noisy sound that the pump makes. I mounted some hard rubber chair leg pads between the pump and frame, but that didn't help much. What kind of rubber do you use to quiet down the pump , or is there any other way to do it? Any other methods anyone has tried? Thanks
  2. 512Stroker
    512Stroker We are all here because we are not all there.
    463
    173
    May 30, 2016
    Freedom, MO
    Local Time:
    5:13 AM
    Common problem with the older style Holley pumps.
    I fought this for a long time with no luck.
    I understand the new style and in tank pumps are very quiet.
    Good luck
  3. Garys72Duster
    469
    267
    Apr 23, 2017
    Brighton, Co
    Local Time:
    4:13 AM
    Thanks! I noticed when it isnt bolted to the frame, its fairly quiet. So going to try and find a way to isolate it, or do a float mount in some way.
  4. DrCharles
    DrCharles Well-Known Member
    438
    157
    Jun 7, 2012
    West Plains, Mo.
    Local Time:
    5:13 AM
    You can probably find something suitable here :)
    McMaster-Carr
    Don't forget that hard line, or stainless braided line, can also transmit a lot of noise to the body. I can't really hear it much over the dual 3" exhaust anyway:rolleyes:
    • Thanks! Thanks! x 2
    • mopardude318
      mopardude318 Well-Known Member
      9,404
      526
      Jan 7, 2005
      Gilroy, Ca
      Local Time:
      3:13 AM
      you can try using a piece of rubber from an old semi truck mud flap.
      • Thanks! Thanks! x 1
      • AJ/FormS
        AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s FABO Gold Member
        15,875
        4788
        Jan 19, 2014
        South-Central Manitoba,Canada, 900ftelevation
        Local Time:
        5:13 AM
        Mount the pump to the flap, and then screw the flap to the frame. make sure the hard lines are allowed to move around with the pump
        • Agree Agree x 1
        • DrCharles
          438
          157
          Jun 7, 2012
          West Plains, Mo.
          Local Time:
          5:13 AM
          For crying out loud, spend $2.09 each for a pair of these! Semi truck mud flaps... hmph ;)
          McMaster-Carr
          • Dennis H
            Dennis H Well-Known Member
            182
            196
            May 29, 2013
            San Jose
            Local Time:
            5:13 AM
            It’s what they do.
          • grjammer
            grjammer FABO Gold Member FABO Gold Member
            662
            78
            Aug 14, 2013
            PA
            Local Time:
            6:13 AM
            just make sure to ground the pump if you end up isolating it that much. A good frame ground is a safety thing
            • Agree Agree x 1
            • DrCharles
              438
              157
              Jun 7, 2012
              West Plains, Mo.
              Local Time:
              5:13 AM
              It needs a ground wire if vibration-isolated properly anyway... putting a slab of rubber under the pump doesn't do much good if the bolts are rigidly attached at each end to the pump and the frame :)
              • Agree Agree x 1
