Do any of yall know if someone makes non chamfered socket sets? As in for use with thin head fasteners. Thank you drive through.
Yeah I have a few I've done that too. Maybe I'll run it by my Snap On dealer and see.I know it's not a direct answer but ......when I have a group of "thin head" fasteners that are all the same size I get a cheapo socket and carefully grind the chamfer portion off. You'll need a cup of water to keep the socket cool so it doesn't loose any of the tempering. I use an extension plugged into the other end of the socket to hang onto it while grinding, a wrap or two of some good tape will keep the socket from flying off the extension. Make sure to keep the end of the socket square as you grind. After grinding use a file to remove any internal burrs. That's all I got!!Don't be a FOOL....keep it COOL!!!!
There's are all chamfered. You need to machine some. They have been chamfered for a decade or longer.Yeah I have a few I've done that too. Maybe I'll run it by my Snap On dealer and see.
Well no, not all. There are a select few in large metric sizes for suspension and bike work, but I am looking for a set in SAE from like 3/8 to 3/4. I'll let yall know if I come up with something.There's are all chamfered. You need to machine some. They have been chamfered for a decade or longer.
If you've got a lathe and nobody makes um, this sounds like a business opportunity for ya. LolUse impact sockets to grind down . They are not usually chromed and will still be strong after thinning . If you have a lathe you could cut the whole set down nice and clean .
I've done that for decades. I WANT a set that's non chamfered. I'm a tool freak. I like tools. Somebody out there has to make something.Wow. I can't believe this hasn't been fixed. You need a socket without a bevel on the end just modify a cheap socket. I sold tools for 3 decades. Buy a cheap socket and grind mill, or turn the bevel off. If you need to use it daily, buy a high quality socket and have it machined to make it work if a specific one isn't available for your needs.
Correct. Only about 5 or 6 in a set and they are all like 23mm or larger.If you search flat faced or flat face sockets, there's some kits out there. Looks like the bicycle crowd is the biggest audience.
I was gonna say a chop saw! Lolimpact socket and chop saw or like i used Metabo
Sawzall them sumbiches!
Yeah but, that's not what I WANT.Well, **** Bro, couldn't Ya just build a jig outta the vise and use the air cut off?
I know...it would be nice to find some made that way.Yeah but, that's not what I WANT.
