[WANTED] NOS Front and Rear Leaf Springs Hangers 250.00 Each
19Duster71
no where
Next up on my A Body wish list is NOS front and rear leaf spring hangers.The front one is the part with 4 studs that bolts into the torque box area and holds the front of the leaf spring.Part #2539489.Then what I would call the rear leaf spring hangers,actually bolts to the frame and holds the leaf spring shackle and then the bottom on the shackle hold the leaf spring.These are the triangle shaped piece.Part #2071764.Looking for NOS only.I'd pay up to 250.00 per piece.Got all 4,that's a 1000.00.Message me here with 1,2 or all 4.Thanks for the ad and the great response.
Check so cal Craigs list. My so cal 67 dart has no under carage rust like the east coast cars do. Also some may have had undercoat on them and never rusted at all.
Im probably not telling you anything you dont already know.:thumbsup:
Front / Rear Spring Bracket
That's what I call the rear hangers and what I am looking for.I see they repop the front hangers for E and B body cars and from what I have learned,the E bodies have the same 4 stud bolt pattern so would bolt up.But the bolt/mounting hole is in a different location so won't interchange?
