Mark Nixon
Senior Moments Member
Rustfree 1990 D-250 2WD, has a getrag 5 speed, 4.10 open rear end and Cummins w/approximately 259,000 miles.
Truck is absolutely rustfree, has some obvious paint peeling issues and was converted over to the '91-'93 Inercooled front clip, both as a repair to a front end dinger, as well as an upgrade to I/C.
Parts replaced at that time were the radiator (upgraded to the later larger cross flow style), core support, passenger's fender, hood and grille, as well as having the intercooler and all plumbing added.
The hood, core support and radiator even still have Mopar part #s on them.
The grille needs replaced, I have a serviceable original one that is included with the truck.
The floor on this truck has been cut out above the transmission to facilitate removal of the top cover on the transmission. The top cover needs re-built. I do have a replacement piece for the floor section that was removed, which will be included.
A replacement top cover is also available.
Interior could use a new seat, or recover the one that's in it, all the interior plastic appears to be good, including both long pieces, the windshield and upper backglass trim. Interior is gray in color.
The steering column needs replaced, due to physical switch issues (turns hard). I have a suitable replacement to include with the truck.
$2000 firm.
For pics, or information, e-mail me at Nixon340@yahoo.com, or call me at 402-780-5127.
$2000 firm.
