Notch back Cuda 383 power steering ?
tooslow
lockport, Il
Hello,
I am building a 68 NB Cuda original SB car . The stroker 383 that is going in is at the machine shop , Done deal
Power Steering, is it possible and how difficult, tips , tricks ?
BOLTS RIGHT IN..JUST HAVE TO USE A DIFFERENT FITTING IN THE PRESSURE HOSE IIRC ON TOP... 68 MANIFOLDS HAVE THE LITTLE NOTCH FOR THE CLEARANCE..
Fit's fine with manifolds. Might not fit fine with some headers. There was a 90 degree fitting on the original cars. Was also used on 340s.
However, you can remove the brass fitting and use a late 70s Cordoba hose with a Saginaw pump.
If assuming a LB 383 stroked, it is, but more than the 90 is needed. If so, I have sourced the correct parts needed to do it right and have that info. Only thing I need is the PS box itself and want to be sure it fits the 383 pitman arm.
