OD or Non OD 833 behind a slant 6?
zpsull01
Corydon, In
I’m considering converting my 75 Valiant (225-auto) to a manual. I have both an OD and a non-OD transmission to choose from. The car currently has stock highway gearing but I don’t see it ever having anything lower than 3.23’s if I ever do change it. It’s just a driver. I’ve heard the slants don’t match up well to a 2.66 gearset due to shift points and where they fall within the power band of the 225’s. Looking for any input on how the 225’s perform when mated to either of these transmissions for street use.
Whoever told you that I was speaking from a standpoint of too little gear to begin with... like 2.76 or something.
Put a 3.55 or 3.91 behind it.
Gosh, with the OD transmission, I would run either a 4.10 or 4.56. The 4.10 would be 2.99 in OD and the 4.56 would be a 3.33. Pretty docile in OD but it would scream on the street.
I’m not really looking to change the rear gearing. This is not a performance car. Just a 4 door survivor that I’m getting back on the street to putter around in. I have my BB Duster for having fun. My main concern was that the 2.66 gearset with 2.76 gears would be so sluggish at times that I would have to be cautious of when I shifted. If it was a decent small block or something I would consider the lower gear sets.
If you want to keep the rear stock, I'd look for an early 4 speed.
Has a 3.09 1st gear but NOT overdrive.
If you run a 2.76 with OD you'll never use 4th, might as well leave the 3 speed in it!
And before you do anything verify what rear gear you've got.
I have a daily driver 68 dart with a slant six/833 OD (1976 transmission) and 2.76 gears.
I only have that highway gear because I couldn't afford to change the rear end when I put the OD in. (Was an auto originally)
I have to rev it up to get going, it's very soft on the take off. On the highway it's a dream because it will do 85 with a relatively low rev (I don't have a tach but I can feel it's not stressing at all at 85)
Its not a hot rod setup but for cruising and highway, it does work. If you are going race off the red light, you might lose to a jap crap fairly often.
I plan to change the rear end and get a lower gear eventually but for the past 4.5 years, it's been a decent daily driver.
It's not going to matter OD or non OD you will drive easier with a lower gear.
When they came from the factory, manual cars always had a lower gear than the automatic counterparts. The torque convertor in an auto had a way to multiply the torque. So they could be used comfortably with a higher gear.
A manual is a direct drive so to be efficient it needs a lower gear. As I said in previous post, I have to rev it up pretty good to take off. They would have never made it like that from the factory because the take off rev defeats the gas saving mentality if the OD.
a non OD isn't going to fix that either, only a lower gear will.
As I also said, I don't think it's an ideal setup but I have it because I was working with what i had laying around the yard and it was supposed to be a driver for a summer and here I was almost 5 years later and still putting up with it.
I'm not talking about performance. Ok, you don't get it, so I'll stop wasting my time.
I get what you mean by the od and final gearing. That’s why I have 4.88’s behind my t56 in my duster. I’m not trying to spend a grand plus changing out the rear just for gearing. I literally have everything to put either trans in the car so I’ll have nothing in it. Just trying to add the 4 speed fun to this car with what I have but wanted to make sure it was going to work before spent the time swapping everything.
But does the Duster have a slant six? What will happen is, with the OD, and possibly even the non OD, you will find yourself downshifting on the highway at the slightest little incline. This is especially true of the OD unit. By going with what most would consider "too much gear", you keep the engine in its designed power band longer and it is still in the beginning of the power band in OD. It will make for a much nicer driving experience.
I do tend to agree though, if you don't go with the lower gears, choose the non OD with the lower first gear set. Good luck!
I'd go with an early 63-65 A833 straight 4 speed with 3.09 1s and 1 to 1 final drive gear.That with a 323 rear is a real sweet set up.I had in in my 65 Barracuda 225 slant six and I also have it now in my Valiant station wagon 170 slant with 323 rear . It's a very driveable combination and gives you decent gas mileage in the 18 to 20 mpg range with the 225 and 22 to 24 MPG with the 170 . You will need to change the drive shaft there is an adapter made to use a regular front universal with the flange type trans.I have one I can photograph for you if you like.I also have an extra one of these transmissions that I'm probably going to sell soon
The guy that did my 273 heads has a 40's Plymouth coupe with a stock 225, a o/d 833 and a 4.10 8 3/4. The thing is real snappy and gets 26 or so on the highway.
OK, given a little more thought about "use what you've got" I'd put the OD in, and pretend it's a 3 speed.
I think that 2.66 first gear will be too hard on your clutch.
If you ever change the rear to something lower, you'll enjoy the OD gear.
The OD should have a 3:09 first gear
I had an OD in a 66 dart with 3.55 SG. I loved it , great mileage good highway cruising and almost 11 to 1 final in first gear.
One other thought to factor into your decision. The split between 1st and 2nd on the OD tranny is huge. The other gear splits are fairly normal. I'm solving it with a slant build designed for as much torque as I can get within my budget. That will help when the tire-frying 1st gear gets going and I have to stick my foot in it to keep it going in 2nd. Cruising on the highway should be pretty economical in OD, and I don't mind having do downshift on a hill.
The od box has ratios of; 3.09-1.67-1.00-.69od. If it has 2.76s, and 25.5" tires, then the final drive will be 1.90 and 65=1630; do you think your slanty can pull that? Even if it can it's gonna take a lot of throttle. The Vcan is probably gonna kick out, and at 1650 your mechanical timing is gonna be around 16 to 20 degrees, while the cruise timing is gonna want to be about 40. And there is not much you can do about the shortfall. This means any economy the 1.90 gearing might have the potential for, will be negated by the lack of timing.
3.23s are not much better, the final drive being 2.22, and 65=1900; you still can't give her the timing she wants with the mechanical distributor. The good news is that at the higher rpm the slanty will have the power, and maybe the Vcan won't kick out all the way. So it will be better, just waaaay short of great.
The problem with the 3.09od-trans is the rpm drops on the shifts. The splits are .54-.60-.69
So if you rev first gear to 3000, still with the 2.76 gears,then when she drops into second, the Rs will be 3000 x .54 =1620@27mph. So, now your slanty is gonna have to have some balls to keep on accelerating. This gear is like second and a half with the regular A833. To continue; the slanty will now pull to 49mph@3000. Then on the shift into third(direct) the Rs will fall to 3000 x.60= 1800@49mph...... and it's a long long way to 65mph @2370 in Direct. To recap, the speeds at 3000rpm will be; 27/49/82.. So in other words, to accelerate briskly, you may have to increase the Rs in each gear.
2370 is a great rpm for the slanty to cruise at, cuz you can set up the D to give her up to about 50* cruize timing, if that is what she wants. But at 65, shifting into OD, chances are you will get better economy in direct than at 1650@65 in overdrive.
Now, if you ask me, that overdrive trans might like a 3.73 rear gear for your slanty.
Your starter gear will be a nice 3.09x3.73=11.53 so taking off is easy..Now, 3000 will get you 20/36/61 in third; still long pulls, but you can't do anything about that. But, the slanty is powering thru the gears quite a bit quicker, and your cruise-rpm will be 65@~2200.
The nice thing about this 3.73combo is cruising at 30 mph in second gear is about 2470, versus 1825 with the 2.76s..... so keeping up in traffic makes for less backshifting.
So what about the 2.66 box?Well, with the 2.76s, and still the 25.5s;
65=2370, a very nice place to be for the slanty, as already mentioned. The ratios are 2.66-1.92-1.40-1.00 and the splits are a much nicer .72-.73-.71 and 3000 will be; 30/41/57, and 30 in second is 2100. This is a bit low, so not as much fun as the 3.73od combo. To match that 30=2470, your 2.66 box would need 3.23s, and your cruise rpm would jump to 2770@65mph. At this rpm, you can probably feed that slanty up to 54* timing if she wants it... and then you can lean out the carb, and get back some fuel economy that the extra 300rpm stole.
Sooooo, what about the 904, 3.23s and a Hi-stall TC? Glad you asked;
The odbox/3.73 take-off ratio above was 11.53. Say you revved that slanty up to an rpm where the engine made 125 ftlbs and slipped out the clutch and the engine delivered that into the clutch,and that got multiplied by the 3.09x3.73=1157 ftlbs by the time it got to the rear axles. Let's just say that rpm was 2600.
Ok so now swap out the clutch and install the 904/ combo. Again at 2600stall now,125ftlbs out to the back will be only 989 by math. But at zero mph, the TC has it's own torque multiplier ratio, which could be as high as 1.8 or more. So at zero mph you could have 1.8x989=1780 ftlbs........... compare that to 1157. Hang on now, this multiplier only lasts for a moment. As the car begins to move the multiplier diminishes and soon settles down to between 10 and maybe 5%. At plus 10% then, your 989 turns into 1088, and this is 94% of that 1157 best. That's pretty good.
In second, the od/3.73 makes a 6.23 ratio, while the 904/3.23/1.1TC makes 5.15, so now we are down to 83%, and falling behind.
Ok but I get that you are trying to make do with what you got. So IMO, if the 2.76s have to stay, then you need to run the 2.66 box. The road gears then (rear gear x trans gears) with the 2.66box/2.76 gears, will be;
--------7.34-5.30-3.86-2.76.. Now with the 904/2.76s/ and 1.1 in the TC, we get
10.14-7.44-4.40-3.04-2.76 not quite as good,lol, but say you just get some 2.94s; then..
10.81-7.92-4.69-3.23-2.94 .. You see what I'm seeing?
The first number you see there in the 10s, are with a TC multiplier of 1.5@ zero mph.I chose 1.5 for a stock-type lo-cost TC. The rest are with the multiplier of 1.1. And the final number is the rear gear at zero slip. This number at cruising speed,can be higher or lower depending on how hard the slanty is working. 2.94s will cruise at 65~2520(zero-slip).
What I see is that your automatic is really behaving like a 5 speed. And with the addition of 2.94s, it is blowing the 2.66box/2.76s away.
If you throw a hi-stall at that combo, it will do even better!
Now here is the clincher;
With a hi-stall, you might be able to throw a whack of timing at her, without running into detonation below the stall speed. So like with say a 2600, you could have 16* at idle increasing to 26*@2600, plus 20* in the can for 46* right there to cruise with. That will help the slanty make some torque and so you may be able to reduce your throttle setting and lean her out. And making more cruise-power with less gas, means "magic"; better fuel-economy..
Ok so the point I'm working up to is that, IMO, the slanty needs the 904, if you just think of the entire combo. The only thing better would be an A998 with a loc-up TC and the 904 gears: IMO.
BTW, with a hi-stall, you might even be able to leave the 2.76s in there. Compare the numbers; up to the top of first gear, say 4000rpm@41mph, the 904/2.76 is besting the 2.66/2.76s.. What about the od box you ask? Well, with 2.76s I get;
.......8.53--4.61--------2.76-1.90 compared to the 904/2.76s
10.14-7.44-4.40-3.04-2.76 the 904 wins again. Splits here are .73-.59-.69-.91 sweet!
Unfortunately, at 30mph this 904/2.76 combo is idling along at a tic under 1600 in second gear, which could slip to 1740 as you press the gas. Not very lively. So she may need to be downshifted, hitting 2950, well that's not so bad. I wouldn't like it much, tho.
Bottom line is; hi-stall and more gear..... IMO
Haven't heard much about tires, they obviously make a difference.
If you're buying some anyway, get the shortest ones with suitable load rating.
This will help with either trans.
There are a couple of A833 slant bells off early cars, I forget the cast #'s, but are not cheap.
I like a 3:23 gear or lower for manual cars. Anything higher especially in a slant takes some effort to get rolling.
Thanks everyone for all the information. Just out of curiosity, what rear gear did most of the /6-od cars come with in 75 and 76?
