Odd slant 6 engine number
64V200conv
Active Member
Philadelphia, Pa
The engine number stamped on the machined boss is only six numbers. 223052. The boss is clean and undamaged. No other marks are visible. I figure it was a factory screw up. Block casting is2463430-7. Engine is in a 64 Valiant 200 conv. Has anyone seen screwed up engine numbers on other blocks? Thanks
Frank
Had a friend with younger and better eyes than mine check the number and he said that there is a Maltese cross after the last 2 in the engine number. .????
From the casting # on the block is this a 66 - 67 block?
Frank
stole this from another link
