# Of Quarts Of Trans Fluid For New B&M
stock pan...deep pan....external cooler?....size of converter?
best thing is put 6 qts in...start in neutral...run thru gears....check in neutral ...add as needed.
For a completely empty trans and torque converter, they usually take about 9 quarts to fill....
I usually just pick up a case in that case....
I'll be doing the same thing shortly except I have new lines and a new radiator also. I'll be buying a case.
