How would airgap vs Offenhauser Turbo-Thrust Power Port 360 with dual Quad Model number off the bottom section is 5940 and the top section is 5915 M, off the line. My goal is for the front wheels to see air. lol See pic Below 2 posts
Here it is.What intake? Got a picture of the combo?
i currently run an eddy street ram .i ran the rpm air-gap before that.although im far from doing wheel stands there are several members here that can vouch for the fact that it is a very streetable set up.they have seen it in person.the air gap made more torque in the lower rpms as you would expect.but i didnt lose enough to make me want to change back considering the amount of power it picked up on top.i think with some good tuning and conservative carbs youll like the end result.hope this helps.Never mind. I'll try them both and figure it out on my own.
Thanks Phista and 340 8BBL, nice to have some intelligent responses. I think with a 422 stroker, solid roller cam .576 lift, 3200 stall, and 4:10 gear, the tunnel ram might be kinda fun.
considering he has a manifold with a top for 2 carbs, id have to say two small carbs.Only KINDA??? That would be BAD A$$!! IMO...
Don't know which would be better though... 2 small carbs or 1 big one.... choices choices choices...
