Offset rear hangers
67DARTGTCONV
Does anyone know of a supplier for the offset rear hangers that have multiple hole locations for the spring. I would like to be able to move the spring around like the RMS relocation boxes.
Thanks
Nope.
You'll run into issues with the a huge hole in your frame rail because of the multiple nuts welded on the bracket. Plus the taper of the rail will cause problem as well.
