'64 Cuda
I'm getting ready to order an offset spring kit from Mancini & had a couple of questions. I've seen people mention that there are 2 different sizes of bolt holes in the front spring bushings. I'm guessing the kit comes set up for the larger bolt. I have a set of factory heavy duty rear springs from a '65 Barracuda. Can anybody tell me which size bolt would be used with these springs? If I need to change the size of the hole in the front bushing, can I just swap to a bushing with the larger hole? Or is the bushing hole in the front of the spring a different diameter too?
One more question. Are the spring hanger reinforcement plates worth using (I'm going to have a built 360 with a 6 bbl. 4 speed & 3.91s) or are they overkill?
Title should have said Offset! I need to do a better job of proofreading!
