or paint those items bright yellow like modern cars, lol.Maybe try to find an owner's manual?? Basic stuff....or even a FSM.
I actually like that especially with the newer black engines in a black engine compartment and me being old and not able to see as good as I used to LOLor paint those items bright yellow like modern cars, lol.
Check the transmission fluid hot in Neutral with the engine idling. The reading you get cold will be incorrect. Go through each gear at idle first (with your foot on the brake) then back to neutral (put the parking brake on).Got it, thank you! I saw a second metal loop at the back of the engine I think is transmission fluid?
So, with that, the level is right below the add line. So add a 1/2 qt?
Last question, should I change the oil filter as well? How do you know that needs changing?
all that and.... when actually checking the level push the clean dipstick fully down into the tube and immediately remove it. if not the oil 'splashing' about in the trans' will give a false reading on the stick.Check the transmission fluid hot in Neutral with the engine idling. The reading you get cold will be incorrect. Go through each gear at idle first (with your foot on the brake) then back to neutral (put the parking brake on).
Fill the transmission fluid (if it needs any) through the transmission dipstick tube. You will need a funnel or use the nozzle that comes with oil container. Put your finger over the end until it's right on the dipstick tube and then slip the nozzle in.
