No oil pressure
You need to go to the FSM to see the oil galleys in the block. The top end oil galleys are run through the cam on its way to the top end. Those oil galleys at the cam are only aligned briefly during the engine rotation. So the cam and its position is needed for oil to flow to the top end. And this is NOT at TDC. No oil will flow to the top end at TDC. You must rotate the engine.
That will not prevent pressure at the gauge. We are not "there" yet
I found it!!!!! Inside the 90 degree filter adapter has an oil passage that should have a pipe plug in it. This explains everything. 3 holes inside of it. One is oil supply to filter, one is oil return from filter. The other is from drilling out oil passages in the block at the factory. That is the one that should have a plug in it. Thanks to all that replied with suggestions.
I don't think that is the problem. I think all that does is bypass the filter.
If they left that plug out then they probably left the one under the distributer out which would cause no oil pressure.
The real question is……..
Will the OP come back with an update as to if it’s fixed or not.
No that did not solve the problem. I now have a small amount of flow at the gauge but only about 2-3 psi. The drill did have a little more drag on it than before, but not like I have experienced in previous engine rebuild start ups. I checked for the plug in the lifter area by the distributor. That plug is there. (See picture). Is there another place that should have a plug that was left out?
Did you check for the drive in welsh type plug in the vertical galley under the oil sender port? I showed that earlier
Did you turn it long enough to fill the filter?
Good luck. Is the builder a "Mopar specialist?"
Also check for cracked/ damaged/ tilted pump caused by oil pan interference, as well as a cracked pickup tube
Please be sure to post back when you find out. Inquiring minds, and all that
One more thing to have the shop check. If they used ARP main studs, the main stud under the oil pump may be hitting the oil pump and causing it to not bolt down flush against the rear main cap. This will result in the oil pump sucking air and not oil. It's been a known issue that ARP refuses to address.
actaully, they *finally* addressed it. sean (NC Enginebuilder) reported that the new kits come with the correct hardware for the oil pump.
You know, not that you mention it, seems I do remember that.
The oil pressure issue is finally resolved. The oil pump was the issue. There was a “burr” on the machined area that mates up to the main cap. (Also the plug left out of the oil filter area) Was allowing oil to dump back into the pan. Looks like it might have been dropped after the machine work was done. Lesson learned. Inspect all parts throughly before installing. Just because they are new parts doesn’t guarantee they are without flaws.
Prelube was completed with a drill and produced 80 psi and all areas are being oiled. Installed engine back in car today and hope to fire it up tomorrow or the next day.
Thanks to all that replied with thoughts and suggestions.
There was a member who JUST experienced this same thing very recently. He ended up removing the pan, priming the pump and that fixed his issue.
Dat was me … never had to do it till this build .
Do you have grooved main bearings ? If not might have to turn crank to align galleys.
Maybe you figured it out by now? Haven’t read entire thread yet.
