dartkory
The gasket between my oil filter adapter and block started leaking so I took it all apart and cleaned the surfaces and will be putting it back together with a new gasket today when I get off work. So I was just wondering if you guys recommend using gasket sealant on that gasket or if its better without it? I used it when I finished the motor about a year ago. Thanks -kory
