So I was just looking around on here and came across some people losing oil pressure because they or their machine shop forgot to install the oil galley plugs. When I got the 360 block I checked to make sure everything was installed correctly, cam bearings, frost plugs and the other oil plugs behind the thrust plate, but I forgot to check the plug that is under the rear main cap! The short block is together, heads and rockers installed. But now I'm freaked out that the machine shop forgot to install it! They installed everything else perfectly, stamped my deck height on the block too. Is there any way to check if it was installed? Or is it rare for a machine shop that mostly works on dodge engines? I think I remember seeing it, but not completely sure.
