Thanks for your reply. I've rotated the motor 20* past tdc after the compression stroke of #6 cylinder, (the location where there should be oil going to the left rockers) and turn pump with a shaft and drill. No luck, must be either cam bearing or possibly faulty cam, (holes not drilled all the way thru on the journal). The cam problem is hard to believe but,they're made by humans too. Also, it IS possible to get a wire all the way down to the cam, you have to take the head bolt out right below the second rocker shaft stand that has the oil feed. I did it using a copper wire but could not feel the cam turn through the wire which could be because the cam bearing is in wrong. Will be pulling cam out as soon as time allows. Thanks again.
