Hello fellow A Body owners. I was wondering if anyone out there has experience with the oil pan removal on a V8 dart? I have a 72 Swinger with a center sump pan. My pan is currently leaking at the drain plug and I would like to remove the pan and repair the plug hole. It seems to be not sealing due to a couple small dings around the drain plug. Unfortunately I would be doing this on my back in the driveway and looking for any experiences and the one you may have had pulling the pan down. My plan is to get it on the bench and knock the dents out and tig weld the threaded bung to the pan.
Thanks
Thanks
