Oil priming fresh built /6
Docmcg
Visalia, CA
Is there a way to prime a fresh built /6? Mine has been sitting on a stand for a while waiting on installing in truck.
Good idea, but is there a way to get the oil to flow thru the system? Want to avoid scoring the dry cylinders.
Another oil pump with no gear on it? That’s what I did with a flathead 8 I rebuilt last year.
I pre-oiled my / with a cheap pressure pot (bug sprayer) form Home Depot, rigged up an adapter at the oil pressure out fitting (at the oil pump), put a quart or two of your break in oil in the pressure pot, give it a few strokes, not too many, and go find something to do for around 30 minutes or so. wouldn't hurt to pull the plugs and give each cylinder a squirt and pull the engine through a few times. Crank her up!
Norm
