Petty Blu 72
Active Member
What would you all recommend for oil in my 340?
Don't know much about the specs on this car from previous owner in Alta
Loma Ca, but I am trying to reach the owner that had it before in Madera Ca. Maybe some one out there recognizes this car?
It certainly has a thumpy cam, and revs quick. I can tell a lot of high performance parts were used. Funny thing, the last owner had it since 2007, drove it 1500 miles or so, and did not change oil, or even remove the wheels! It has an over sized oil pan, so not sure how many quarts it takes. Not even sure what year block the 340 is. I can run those numbers later I guess. I am sure at one point is was used for bracket or quarter mile drag, just because of reverse valve body trans, no heat, radio, gas gauge,etc.
Anyway, I'll get to my question, what viscosity and brand of oil would you guys recommend? 8)
