Oil Relocation Kit??
FPSsnake
New Member
TN
Hey whats going on guys? I am in need of some help here as I am completely stumped on what I need. I have a 1965 Formula S Barracuda with a 1972 360 V8 small block from a duster from which I hear is a common swap with these vehicles. I had to buy custom headers for this vehicle but I need an oil relocation kit since the headers on the passenger side fits too close for me to get an oil filter on there. So my question is which kit should I get or if anyone else has already done this swap what did you use?
Too close for a standard 360 position. Is it too close for the original 273 90 deg. adapter? if so.....there are relocation kits, but the outlets are almost as proud as the stock short filter.
If the 90* OE oil adapter doesn't work, and I don't know why it would not, but, Summit racing has oil filter relocation kits. Also purchase a pair of 45* screw in fittings. The kit comes with straight fiffings which may get in the headers way. Our base the kit with 96 inch oil line.
Tighten it down really hard and you'll be fine.
