dartfreak75
Restore it, Dont part it!
Yep thats the one!
I called shell oil technical support and one of the engineers ahs confirmed that Rotella T4 has is also for older flat tappet engines with 1200 ppm ZDDP.I have a 1977 440 with flat tappet hydraulic cam is there any oil out there off the shelve with the required ZDDP to run in this engine? If not what would be a safe conventional oil and what is a good additive that I could use that is readily available again off the shelve?
Thank you in advance...
Synthetic blendI called shell oil technical support and one of the engineers ahs confirmed that Rotella T4 has is also for older flat tappet engines with 1200 ppm ZDDP.
Thank you for all your advice was very helpful
Synthetic blend
