OK please explain H code
dart6
New Zealand
I thought H code pertained to a factory 340ci car.
Yet there is a 69 dart in the 4 sale section listed as a H code yet is factory 383
There is a code further down the listing that tends to give credence to the 383 being H code too
It's a beautiful car too
Engine code H means different things based on the model year.
As an example, H code in 66 indicated hemi engine while H in 1967- 69 meant 383 4 bbl. For 1970-71, H meant 340/275 hp, but for 1972-73, H indicated 340 / 240 hp. You have to know the year to determine the engine code.
100% true and accurate!
Codes go by year and the letter represents the engine as far as h goes from 1970-1973 h is for 340 4 bbl
So it's like this b -198 /6 -c 225 /6
G-318
H - 340
70 only J- 340- 6 bbl
L 383 - 2 bbl
N - 383 magnum 4 bbl
U- 440 magnum
V- 70-71 (very rare 72 ) 440- 6bbl
R 70-71 Hemi
I can't remember 400 ?
But any way I'm sure you can see the logic in the coding .
Ok so I had to go look
71 up
K- 360 2 bbl
M- 400-2bbl
P- 400 - 4 bbl
69 - M stood 440 in a bodies
And 69 1/2 m code was 440/6bbl
At least from how I understand it that's the way the codes work on the 5th digit .
As stated 68-69 340 was different as were others and stated h meant Hemi in earlier vins .
My 68 Dart GTS is H code 383, as stated above, depends upon year.
So is the pic in your avatar your Dart ?
Did it come from the factory with the color combo ?
Is it f8 green with the red stripe ?
Regardless if it's original ?
I think your car is stunning !!!
If it's original it just adds more !!!
Yeah.. We have a guy on the Coffee thread that does renderings of your car on his computer. He is a real artist. In 68 the dark green is GG1. This car is numbers matching, with all documentation. It came with a white tail stripe, but I'm gonna put a red one on it , since I want to use red line tires, and the GTS emblems with the red background. Just want to be different. Car is NOT finished yet. And I have 2 other cars to restore. Long Road. You can check the build thread on it at the bottom, by my signature here.....
Cheers all
As i have a 70 Dart with numbered 340 and knew it to be a H code car, i was a little confused
Thanks again
68-69
H=383
P=340
1970
H=340
I see! You meant the 5th digit...
1970 Codes:
First digit = car line
B - Plymouth Barracuda ("E" Body)
C - Chrysler Newport, 300, New Yorker ("C" body)
D - Dodge Polara, Monaco ("C" body)
J - Dodge Challenger ("E" Body)
L - Dodge Dart ("A" Body)
P - Plymouth Fury ("C" body)
R - Plymouth Belvedere, Satellite ("B" body)
V - Plymouth Valiant, Duster ("A" body)
W - Dodge Coronet ("B" body)
X - Dodge Charger ("B" body)
Y - Imperial Crown, LeBaron ("C" body)
Second digit = Price class
E - Economy
L - Low
M - Medium
H - High
P - Premium
S - Special
K - Police
T - Taxi
N - New York Taxi
Third and fourth digits = body style
21 - 2 door sedan or coupe
23 - 2 door hardtop
27 - Convertible
29 - 2 door sports hardtop
41 - 4 door sedan
43 - 4 door hardtop
45 - 6 passenger station wagon
46 - 9 passenger station wagon
Fifth digit = engine
B - 198 1-1BBL 6 Cylinder "G" engine
C - 225 1-1BBL 6 Cylinder "RG" engine
E - Special Order 6 Cylinder engine
G - 318 1-2BBL 8 Cylinder "LA" engine
H - 340 1-4BBL 8 Cylinder "LA" engine (High Performance)
J - 340 3-2BBL 8 Cylinder "LA" engine (High Performance)
K - 360 1-2BBL 8 Cylinder "LA" engine
L - 383 1-2BBL 8 Cylinder "B" engine
N - 383 1-4BBL 8 Cylinder "B" engine (High Performance)
R - 426 2-4BBL 8 Cylinder "RB" engine (Hemi)
T - 440 1-4BBL 8 Cylinder "RB" engine
U - 440 1-4BBL 8 Cylinder "RB" engine (High Performance)
V - 440 3-2BBL 8 Cylinder "RB" engine (High Performance)
Z - Special Order 8 Cylinder engine
Sixth digit = model year
0 - 1970
Seventh Digit = Assembly Plant
A - Lynch Road, Michigan
B - Hamtramck, Michigan
C - Jefferson, Michigan
D - Belvedere, Illinois
E - Los Angeles, California
F - Newark, Delaware
G - St. Louis, Missouri
H - New Stanton, Pennsylvania
R - Windsor, Ontario, Canada
1970 Codes:
E - Economy
L - Low
M - Medium
H - High
P - Premium
S - Special
K - Police
T - Taxi
N - New York Taxi
23 - 2 door hardtop
27 - Convertible
41 - 4 door sedan
43 - 4 door hardtop
0 - 1970
Yep
