rmchrgr
Skate And Destroy
OK, anyone know where to get one of these bushing clips?
http://i273.photobucket.com/albums/jj214/rmchrgr/IMG_0401_zpsf40d268e.jpg
This is for a '64 880 my friend and I are working on. This bushing snaps into a bracket that comes off the bell housing and keeps the throttle rod/kickown pivot in place. We swapped intakes from a 2bbl to 4bbl and when we went to adjust the kickdown, we found there was a lot play in the linkage. I started looking around and it turns out this little bushing was the culprit. You can see from the pic that the flange on the one side disintegrated allowing the pivot to move around.
This is the bracket where it clips into. You can see the u shaped slot where the bushing snaps into. The larger diameter rod is held in place by the clip.
http://i273.photobucket.com/albums/jj214/rmchrgr/IMG_0403_zpsd2315cdc.jpg
Hopefully someone can point me in the right direction or has a suitable fix. I tried a nylon washer and spring clip one side but it wouldn't stay. The flange and locking tabs keep it in place. It's like a little tension clip.
Sorry for the huge pics.
