The torque converter pilot is different (early 1.55" vs late 1.80"). A simple adapter sleeve would have to be made or vibration/flex plate damage could happen. You can't swap the torque converter to the later style unless the transmission input shaft is changed because the splines are different from early to late.
So, behind at the crank is a 1.55 hole?
67 and older small blocks and /6's have the smaller 1.55" hole in the crank. 68 and up have a 1.81" pilot hole.
Ragtop I've seen the adapter ring on e-bay in the past but at the moment I ain't coming up with it. I'll keep looking
IF I'm reading the posts right, a 71 904 should bolt up to a 95-97 5.9 mag. Am I right??
thanks Jim
Thanks
Wondering if my 64 /6 trans I have in it now has the adapter since the motor is a 68 according to the block #'s ?
How about the 67 down torque converter working with the newer 68 up motor ?It'd be easy to tell. Just measure the o.d. of the torque converter register. If it's 1.81" it's either a newer trans or has the adapter ring on it, which you should be able to see.
thanks Jim
your right Fishy on what he has but I have the 71didn't intend to hijack his post tho so very sorry if I did
Jim
thanks Jim
