EDIT Because you have an idle air control, I'd say you probably have a Commander 950, or there's some chance it even has an HP ECU. You need to examine the "box."
That could be one of two systems, the "far worse" older systems that had several adjustments sticking out the box, or ......
the much better Holley Commander 950, which is fully programmable, just not "self learning."
So you need to find the box and find out what you have.
The "round top" injectors don't seem to be available, and Holley seems to use proprietary injectors. I have a Holly TBI 2bbl built for "OEM replacement" and the connectors are different on those than on the aftermarket system I've got
Here...........
http://www.forabodiesonly.com/mopar/showthread.php?t=209528
The photo in the first post is a Commander 950 I bought, look carefully at the TB. It has the "new style" injectors. There are TWO variations of ECU for this unit, as well as older / newer software, but you can send the box into Holley and they can "flash" it to the new firmware, and will send you a copy of the new software. You can also download the software from Holley. If you have the older firmware YOU CAN NOT use the newest Holley 950 software
Down in post 11 is a used "2D" which has the cheaper "adjustable" ECU I mentioned. There are several variations of these systems, including an older box
This is the ECU which I upgraded "to" recently. Used most of my old hardware, and my old Commander 950 TBI unit
http://www.forabodiesonly.com/mopar/showthread.php?p=1970081758
Check out the Holley Forums:
http://forums.holley.com/forum.php
Some of the Commander 950 stuff is still available here, including both the hardware and software / programming manuals.
http://www.holley.com/TechService/Library.asp
By the way you need to remove and resize your photo, as it REALLY effs up the display on this site............
